ls1 T56
Old Jan 26, 2014 | 08:48 AM
80bu's Avatar
Default ls1 T56
I have a 80 Malibu with a ls1 t56 and I need to remove the trans to have 2nd gear syncro put in it. I was wondering if it's easier to pull just the trans and separate it from the bell housing or pull the whole thing? I just didn't want to bleed the hydraulics again if I didn't need to.
Old Jan 26, 2014 | 09:15 AM
Forcepower's Avatar
The slave is bolted to the mid plate. So no matter which of the 2 routes you go, it's going to be a pita.Bleeding the hydraulics again might be the easier route if doing this by yourself.
Old Jan 26, 2014 | 09:19 AM
BigEd_72455's Avatar
unbolt the front clip and pull it all!!! don't forget the clutch cylinder off the firewall.
lol
