Power Steering Pump on a 2013+up LS3
Old Jan 27, 2014 | 04:47 PM
OLDSMAN's Avatar
Lightbulb Power Steering Pump on a 2013+up LS3
Maybe this has been asked and answered, but can a power steering pump be added to the accessory drive of a 2013 and up LS3 ? In pictures, I see 2 idlers in place of the pump.
Old Jan 27, 2014 | 05:55 PM
-TheBandit-'s Avatar
I don't know why it couldn't be. The 2010 Camaro pump bolts to the front of the cylinder head. Unless they eliminated the 3 mounting provisions on the front of the head, you should still be able to mount the PS pump.
Old Jan 27, 2014 | 06:04 PM
OLDSMAN's Avatar
I'm looking to purchase on Ebay and have seen some prospects there.
Try this: http://www.ebay.com/itm/161208468774...#ht_115wt_1166
Old Jan 27, 2014 | 06:12 PM
Funny I was just looking at the same ebay ad for finding reference photos. It looks pretty clear from the photo that the new idlers mount to the original holes in the cylinder head that the pump used to mount to. You should be able to mount a 2010-2012 Camaro PS pump without a problem or use an aftermarket FEAD.
Also I will note those new idlers are about the biggest bandaid I've ever seen. I can understand why they went that route rather than properly reworking the FEAD belt path, but wow that is an ugly solution to eliminating the PS pump.
Old Jan 31, 2014 | 02:08 PM
OLDSMAN's Avatar
Thanks Bandit. There were a lot more reads, but no different opinions. Now I just have to pony up!
Old Jan 31, 2014 | 02:55 PM
CBM Motorsports's Avatar
The 2010 Camaro bracket will work just fine. You can even use an aftermarket pump like a Sweet (for remote reservoir) on that bracket. The good news is that the bracket is only $25! Let me know if you need one.
