Removing wiring
Old Jan 28, 2014 | 08:20 AM
LsoneGT's Avatar
Default Removing wiring
I have a 99 Mustang with a ls swap. Previously I had a 4l60e in and switched over to a glide and want to remove all the neutral safety switch,speed,sensor, etc wiring. Anything to do with the trans. Are any of these wires needed or can I just trace them bact to the pcm and remove them? thanks
Old Jan 28, 2014 | 07:23 PM
i r teh noobz's Avatar
I believe the VSS input is needed to prevent stalling at stops. The other stuff shouldn't be needed if you use a 6 speed tune.
Old Jan 29, 2014 | 06:34 AM
LsoneGT's Avatar
Thanks for the reply. Im guessing I can just turn off anything I don't use with hptuners. The car has been running fine without any of those plugged in I'm just wanting to clean up a little.
