2003 Ls1 5.3l
i need some help. i just bought a stripped 2003 LS1 5.3L engine. i need to aquire a intake manifold, and computer w/ wiring harness. can someone help me with some GM part numbers?? also i found a used factory intake manifold from a 2000 5.7 LS1 engine. i have been told that this will fit any gen III LS1, is this true? will it bolt directly on? so i have to do any other mods to it to make it work for my application?
thanks in advance for all you help.
Troy
ps. this is being installed into a 97 jeep wrangler, so needless to say, im starting from scatch.
thank you for your help. do you by chance know of the part numbers that i would need? and does the C5 intake just bolt on, to the 5.3L?
thanks again
thank you for all your help. i work for ACDelco, and i was thinking they might have these intakes in the warehouse. i get a huge discount on parts, but i have to have the part number available when i order it from work.
can anyone help me with the computer (ECM) and wiring harness?
Thank you,
Troy
For the computer & harness, you have a few options. Buy new (truck, Vette, F-body use the same computer, but with different software) or find used. The harness will have to be modified to work "stand-alone". You can talk to Speartech about harness conversions. Another option is a Painless harness but I believe that they only work with '97&'98 PCMs that are harder to find.
Do some searching in the Hybrid section and you should get most of your questions answered.
-Matt
