Holley swap pan question
The new Holley swap pan comes with a small aluminum part that gets bolted onto the pan just above the oil filter.
My old pan has a similar part that has a sending unit in it.
My Ls1 is from a 2004 corvette. I'm not sure which part to use.
Will the ECM want this sending unit to be connected or is it not necessary?
I'm not sure what this sending unit does.
Thanks, Dan
Whether or not the ECM wants the sending unit, I have no idea. The fact that it exists probably means that it is wanted, so installing it even if it is unused is a measure of insurance.
My car has an oil pressure gauge and an oil pressure dummy light. I put the gauge sending unit up on the top of the block where the OE sender is, but I used the port you have pictured for an oil pressure switch for my dash dummy light.
