lq4 with stand alone going into 98vette
Old Feb 16, 2014 | 08:05 AM
jesselee128's Avatar
Default lq4 with stand alone going into 98vette
Harness is almost done being made. It's a 01 5.3 donor harness being switched to cable drive throttle body. My question is -- how am I going to get gauges to work with the stock 98 vette cluster
Old Feb 16, 2014 | 09:54 AM
REDCYCLE13's Avatar
any reason you wouldn't use the stock corvette harness?
Old Feb 16, 2014 | 12:06 PM
Well the swap started out as a 95 6.0 camaro swap... but i bought a 98 vette roller lol. Will the harness just match right up?
Old Feb 16, 2014 | 12:07 PM
No harness with the roller btw.
Old Feb 16, 2014 | 04:04 PM
tfi racing's Avatar
What style PCM does the 98 use and what runs the guages(PCM or BCM)?It may just need programming of your 0411 PCM to make the guages work.If no one here has done this swap,I'm sure the will be a few on the Corvette Forum that can help you out.
