Holley Crossmember
Old Feb 18, 2014 | 06:40 AM
Danny Thomas's Avatar
Default Holley Crossmember
Does the holley cross member work with dirty dingo mounts. Putting ls1 with a 4l60e in an 81 trans am.
Old Feb 18, 2014 | 07:07 AM
dondb's Avatar
I'm currently putting the whole Holley kit into my LS swap. Here is a picture of the cross member installed in my 69 camaro. If the Dingo mounts are the same height (frame to engine) as the Holley motor mount set up, i don't see why it wouldn't work? The Holley set up sets the frame to engine at 3-5/8".
Old Feb 18, 2014 | 11:21 AM
user 4737373's Avatar
No it won't Danny as the Hooker (not Holley) crossmembers for the 2nd-gen applications feature the same unique design geometry of the Hooker engine brackets for the same that centers the engine and transmission in the subframe. This is similar to the engine/trans alignment you will have when running many of the popular aftermarket subframes and unlike the stock passenger side offset that will be maintained when you use the Dirty Dingo or any other brand of swap plates.
The Hooker parts are designed as a system and cannot successfully be used in a mix and match fashion as parts have been in the past...you will have issues in doing so.
I hope this helps.
Old Feb 18, 2014 | 08:36 PM
I hope this helps.
Thanks for the info..Guess I will flip original cross member and redo tab
Old Feb 18, 2014 | 10:13 PM
That's another way to skin the same cat.
