Alternator Amperage
Old Mar 8, 2014 | 01:09 PM
Pig Pen's Avatar
Default Alternator Amperage
How many amps do I need to run just a 6.0 engine, no accessories or anything. I've been running it without an alternator but I'm tired of charging the battery all of the time.
Old Mar 8, 2014 | 01:42 PM
bczee's Avatar
Question.. what other electrical devices are you running ?.. Fans, radio, lights, AC, Heater Fan, etc ?
If you looking to just run then engine. 40+ amps would be enough. Add up what you have, Electrical Fans, Fuel Pump and anything else you have.
Most GM cars and trucks now a days have 100 - 140 amp alternator to handle the load of all of the electrical devices and load, which includes the engine, lights, seat warmers, AC, USB ports, etc..
Old Mar 8, 2014 | 01:51 PM
Pig Pen's Avatar
It's in a boat, I'm not running anything else other than a bilge pump occasionally and possibly the navigation lights if I get caught out at dusk.
Old Mar 8, 2014 | 05:45 PM
Pop N Wood's Avatar
The EFI stuff draws a surprising amount of current. Just look at the fuse sizes for the computer, heated oxygen sensors (if you have them) and fuel pump. For a ball park number just add up whatever fuses you have feeding the engine equipment.
Having said that I would think any alternator you put on there will be more than large enough. Even the old carb'd motors had alternators that would produce 45+ amps.
Old Mar 8, 2014 | 06:52 PM
bczee's Avatar
IIRC.. the 70's era 10SI were maxed out at 48/63amp and the next generation were 12SI were 78/90amps. These newer generation of Alternators are 100/140amps..
If your worried about size.. you can try a Japanese Import Alternator.. they are small and can produce enough amps for your boat.
