lt1 to ls1 swap no start
C Orange Power feed from PCM BAT fuse to PCM
D Red Feed from fuel pump and fuel pump relay to prime connector.
all this trouble for nothing. lol
bp auto and merv u guys are the best at troubleshooting. i owe you guys. here soon PM me your addressed and i will make all this troubleshooting worth a surprise
This wire is the 12v Constant Power to the PCM.
as for the 9 red pcm wire. The pcm is getting contant power cuz its hooked up straight to the battery/starter wires that build in the psi harness.
now with the new fuel pump. I'm back to square one. No fuel.
I know like u said 4 wires. Its not rocked science. Its just weird that its still not functioning how its suppose to. On the grey wire in not getting any voltage. My battery is very low on power also. I have to recharge it after every 6 key turns.
something tells me this problem is something so easy I just can't see it.
#30 - Pink - 12v
#87 - Grey - 0v
#86 - Black - 0.13v
#85 - green/white - 0.01v (this number stars at 5v and then drops to 0.01v)
on the 97 formula its like this.
#30 - Grey - 0v
#87 - Orange - 12v
#86 - black - 0v
#85 - green/white - 0v
on the formula it has 0v on the black which is for ground? could that be the problem?
the brake booseter and the ls1 intake hose were open. so i decided to close them with my dads help and now it idles hard, do to the throttle body wire not aligned properly.
#30 - Pink - 12v
#87 - Grey - 0v
#86 - Black - 0.13v
#30 - Grey - 0v
#87 - Orange - 12v
#86 - black - 0v
Terminal 30 is the POWER IN TO THE RELAY, 87 is the POWER OUT TO THE PUMP.
A Relay is a switch, when it's turned on, it takes the 30, connects it with the 87, and makes **** happen. 85 and 86 are the two wires that make it turn on.
4 pages posted when you could be driving the car.
It makes me curious as to what they sent you.
What i also noticed is that the fuel itself is dirty. its kind of orange/yelow fuel coming out of the fuel pressure gauge via the plastic tube thingy. time to take out the fuel and swap in a fuel filter.
If that doesnt help. Im just going to have a technician fix this for me.
I just got a diagram off AllData for my 97 Firebird.
It stated that #87 is orange and hot at all times. comes from the PCM Bat Fuse 15amp.
I will double check this after work and post it.
I installed a new fuel pump and it has fuel pressure sometimes.
and when it does it, it only holds pressure for like 1 minutes and after no more fuel pressure or power to the fuel pump.
i tested the fuel pump out of the fuel tank and it primes. of course i only test it for like 2 seconds. dont want to burn it without fuel. i give it ground and 12v source.
i also purchased a new fuel pump relay and test it.
i will post the diagram here after work.
seems that 30 is one that goes to the fuel pump (grey wire) and 87 is the one that is 12v. which i just checked and the 87 is orange is giving me 12v. #87 switches it to #30 for the 12v to go to the fuel pump. which in my case thats not happening.
below 97 pontiac LT1
below is the diagram for the 95 Camaro.
So basically my wiring is correct and the #87(12v) is not switching to #30 to give the Fuel Pump 12v.
i did the following. i basically wired the black ground wire to a different ground source on the chassis. soon as i turned the key i heard the fuel pump prime and got fuel pressure. thats permanent fuel pressure. lol. im so excited right now.
i will rewire that ground. now all i need to do is get my dual cats and a y pipe and hook it up to my stock remaining exhaust. get my registration sticker and pass emissions.
now so far the only issue i have is im getting some smoke coming out from god knows where. i dont have have the o2 sensors yet. im guessing the header gaskets are getting acclimated or the oil pan gaskets. i do have oil. mayme some oil leak somewhere or some wire getting touched by the headers. i will check all this out this comming weekend.
forgot to mention i need to steady the idle on the throttle body cable.
thanks everyone for the awesome help. i will make sure all my grounds dont have paint and are clean.
