Using LS7 MAF with LQ4 harness - pinout differences
Old Jul 8, 2014 | 10:15 AM
69MyWay's Avatar
If you tuned your vehicle to run the LS7 MAF - but then put the LS1 maf back in PRIOR to re-tuning...what do you think the results would be? Lean...rich...No run at all?
Old Jul 8, 2014 | 02:51 PM
JetMech442's Avatar
For an LS1 MAF with LS3/7 tables:
Lets say the engine is injesting 180 g/s. The LS1 MAF would report 9000 Hz. The LS3 tables however would interperet 9000 hz as 400 g/s. The PCM would then fuel to 400g/s, which wold cause a rich condition(cause your only really getting 180g/s.)
In the lower airflow regions, the tables aren't too disimilar, so it might not be that bad until you get into high load/rpm regions.
Old Jul 8, 2014 | 03:10 PM
69MyWay's Avatar
Thank you! That helps explain. I often get what will cause something to go lean or rich backwards in my head.
And...if you just leave it unplugged for a bit UNTIL you can retune - it just won't run very well at all - but should run...eh?
Old Jul 8, 2014 | 04:38 PM
JetMech442's Avatar
I would think the STFT would be going crazy trying to lean it back out. It might be able to learn around it but I guess I'm too chicken to go try it out...
Old Jul 8, 2014 | 04:52 PM
69MyWay's Avatar
I'm trying to get it to run well enough to charge the ac and get it on and off the trailer to the dyno tuner.
Where a lot of people are putting larger mafs on their car, I'm trying to scale this one back because for all it has in peak hp it has drive ability issues that I believe can go away with the right combo of parts and tuning. Had the 802 green blue PCM on a red blue harness and other modified things.
We can always go back big.
Old Jul 23, 2014 | 11:46 PM
Sommer86's Avatar
This is great info! But does anyone have any ideas about what pins need to be swapped in a Calloway 100mm MAF to work in an LS1 harness? We have the LS1 3 pin/2 pin to 5 pin adaptor, but we're throwing a MAF code. Since it's a Corvette MAF, I've read that we need to re-pin the MAF to work with an LS1 camaro harness.
