'72 Nova trans cooler insight...
I've put a 4l80e in my '72, but I'm struggling deciding what, where, and how to put the cooler in. It will not be low on HP eventually, and the 4l80e is fully built, so I need plenty of cooling.
Pictures or links to your threads are a huge help, thanks.
Made hardlines to run from the trans to the bracket at the front of the engine. Then softline from the engine to bulkhead fittings in the core support. Where the hardlines run under the starter I did wrap them in heat shield since they are about 1" from the headers. Total investment...maybe $60 and about 10hr of work.
Hard lines routed on top of Subframe.
SS Hard Lines and AN ends (bent up and ready to install).
BC
My main issue is that I have an intercooler up front on my core support taking up most of the real estate so a big square cooler probably won't be an option. I think I can get away with a long rectangle one behind the bumper though.
Has anyone had any issues not cooling enough with the cooler mounted somewhere else on the car?
I was thinking the driver's side of the trans under the car is an option since my downpipe isn't routed on that side...
