Harness and PCM question
Old Apr 20, 2014 | 10:48 PM
69CT's Avatar
Default Harness and PCM question
I'm trying to put a LS-3 in a 69 Camaro. I have a few questions. I bought a stand alone harness from GM. It's not long enough to put the PCM where I want. Can I buy a extension or should I send the harness off to be extended?The fuse box wires are also too short. Can they be extended?to get the wire into the gas pedal can you take the plug apart or so you drill a hole big enough dor the plug?And what's the best way to mount the PCM?thanks a lot for any help
