Coolant Temp Sensor Location
BTW, is this sensor just for the computer or is it also for gauges?
Andrew
Btw, the 98 f body uses a 3 wire sender. 1 wire for ecu, 1 for the gauge. All others use a 2 wire where the sender feeds the ecu, then the ecu operates the gauge.
You can get a 98 Camaro 3 wire unit and use the appropriate wire for the gauge. If it's in the wrong resistance range for the gauge, you can correct to some extent with a resistor.
