Clutch pedal help.
Old May 10, 2014 | 01:08 PM
70oldschool's Avatar
Default Clutch pedal help.
So I'm using a 2002 z28 m6 for my swap into my 70 chevelle that was automatic. Is it a better bet to use the pedals from the camaro and try to mount them in the chevelle or should I buy chevelle specific pedals and have lines built to fit the t56? Has anyone done this? Thanks
Old May 10, 2014 | 01:42 PM
garys 68's Avatar
Lots of A body conversions here. This should keep you busy reading the rest of the weekend.
https://ls1tech.com/forums/conversio...2-gm-body.html
Old May 10, 2014 | 07:20 PM
bczee's Avatar
I just used the OEM Chevelle pedal setup and used the adapter plate to use the 4th gen master. It is not that hard to setup.
