Different makes of Throttle pedals, Anybody try to make work?
I'm thinking that since they both have 5v going to them then the return signal wire shouldn't fry the PCM. Maybe won't work right but it shouldn't do any harm??? This would save me so much extra work not having to take apart the dash and mounting the GM pedal and having to extend the GM pedal wiring.
Anybody tried using a different manufactures pedal? Both cars are obd2 also.
Thanks, Michael
5v+ you would parallel this at the pedal
5v- you would parallel this at the pedal
pp#1 this sweep goes up
pp#2 this sweep goes down
you won't hurt anything if hooked up wrong. but won't work
The sweeps must be in the right correlation to work properly
Porsche Pedal (6 wires total, 3 to each sensor)
Sensor 1
Grd to Sig, 1.27 , 1.9
Grd to 5v, 1.2 , N/C
Sig to 5v, 2.15 , 1.5
Sensor 2
Grd to Sig, 1.16 , 1.56
Grd to 5v, 1.69 , N/C
Sig to 5v, 2.59, 2.15
GM Pedal (6 wires total, 3 to each sensor)
Sensor 1
Grd to Sig, 1.3, 2.1
Grd to 5v, 1.1, N/C
Sig to 5v, 2.0, 1.3
Sensor 2
Grd to Sig, 1.3, 2.2
Grd to 5v, 1.6, N/C
Sig to 5v, 2.6, 2.4
First number is Idle, Second is Full throttle
Grd= Ground
Sig= Signal Wire
5v= 5 volt supply
N/C= No Change
I'm not saying it won't work, I'm just saying if you get it working in the garage on stands or in the driveway, don't break out the champagne just yet. I had an 2007 Silverado engine we made some changes to and it took about fifteen miles or more for it to decide it didn't like something between the calibration and pedal.
Of course going dead pedal is better than the Toyota alternative!
