E40 PCM ac wiring help.
Old May 22, 2014 | 10:18 AM
oldgoat69's Avatar
Default E40 PCM ac wiring help.
The plan is to trigger the PCM when the AC is switched on to step up the idle and activate the fan.
I see 3 pins in the blue connector referenced.
Pin 26 = A/C pressure signal
Pin 30 = A/C pressure +5
Pin 55 = A/C pressure signal
I have 2 terminals on the pressure switch, #1 12v in, #2 12 v to compressor. I understand that I need to use the #2 terminal for the signal. To which PCM pin do I connect?
My guess is not Pin 30, what do Pin 26 and Pin 55 control?
Old May 22, 2014 | 10:53 AM
BigEd_72455's Avatar
Send a message to Brendan over at LT1swap.com and he should be able to tell you what you need to know.
Old May 22, 2014 | 12:26 PM
sick_46's Avatar
I too would like to know the answer. please post it up here if you figure it out
Old May 22, 2014 | 04:50 PM
oldgoat69's Avatar
Brendan does not support the E40, I asked him first. After a bit more research it appears that Pin 26 is the one to trigger. I will try that and post the result.
Old May 23, 2014 | 12:12 PM
oldgoat69's Avatar
I have verified that Blue Pin 26 is correct on the E40 PCM. The circuit # is 380 and seems to be universal. On the GMT800 blue/green PCM it is Green 14.
Old May 23, 2014 | 12:55 PM
Congrats and good work on chasing down this info. See if you can get a mod to pin it to the top or maybe make it a sticky.
