converting throttle by wire too throttel by cable
Old May 23, 2014 | 02:38 PM
boostedrides's Avatar
Default converting throttle by wire too throttel by cable
I know that the throttle body would have to be changed, but what else would be required. I bought a 93 camaro with a, t56, 5.3 throttle by wire swap, and would like to switch over to a throttle by cable setup. Could I just have the computer reflashed? Are there any other things I would have to worry about? Thanks in advance for any help.
Old May 23, 2014 | 03:04 PM
CBM Motorsports's Avatar
This may or may not be an easy swap. Do you know what computer you are using? Some computers can only control one style of throttle bodies. So long story short, you would probably need a new computer and harness.
Old May 23, 2014 | 04:41 PM
aknovaman's Avatar
Use the existing electronic throttle body wires for the tps and iac. Move the DBW wires to the respective PCM connector positions used for DBW. Load a DBW express van file if it's a green/blue PCM or a Camaro file if it's a red/blue PCM. This will work if it's a ls1 style PCM.
No need for a new harness just a few solder connections and move a couple PCM wires.
It's really not difficult nor require additional expensive new parts.
Old May 24, 2014 | 08:41 PM
1FastBrick's Avatar
You can repin the harness as mentioned, However some of the 03-07 classic PCM's do not support the DBC even with a flash.
This page explains the internal difference---> http://www.lt1swap.com/cable_conversion.htm
Old May 24, 2014 | 08:54 PM
Forcepower's Avatar
first step is to figure out if your engine has a 24x or 58x reluctor wheel on the crank. What pcm is running the car now?
