Oil sender for swap
Old May 26, 2014 | 12:42 PM
dkiller2135's Avatar
Default Oil sender for swap
Im looking for a oil sending unit for my swap.
What part is everyone using?
Im seeing the adaptors for a 1/8th NPT tread but there isn't much room for the sending units im finding.
Thanks for any ideas.
Old May 26, 2014 | 02:48 PM
M.BOZZ's Avatar
That's funny, im doing the same thing. You have to use the #2268 adaptor and I ordered the gauge #4327 but I don't like the big sending unit so im still looking for a sender.
Old May 26, 2014 | 09:14 PM
spacemanspif's Avatar
The adapter is for the sending unit location behind the intake. Many others use the stock sender and gut it, drill it and tap it for the 1/8npt threads of most common senders. If space is limited consider using 45 or 90 degree fittings to make more space. Another option is to drill and tap the bypass cover just above the filter but that has its own problems with header clearance...
Old May 27, 2014 | 08:27 AM
Ive seen the bypass option aswell. And thought about the 90 degree option. but I just assumed there would be a kit for the engines since they are a popular swap. I would like to find find a small sending unit.
I may just run tubing to a mechanical gauge is i cant find a sending unit to fit.
Old May 27, 2014 | 08:43 AM
88Fbody6L's Avatar
I drilled and tapped the bypass and ran an 1/8" copper line in to my mechanical gauge.
Old May 27, 2014 | 11:46 AM
Chris05's Avatar
http://www.speedwaymotors.com/Auto-M...ter,20928.html I used this on my swap
