Summit Correct-Align Power Steering bracket?
Old Jun 1, 2014 | 10:16 AM
ryanleiker's Avatar
Default Summit Correct-Align Power Steering bracket?
Has anyone run the Summit Correct-Align power steering (type II) brackets?
I may need to replace my pump and upgrade in the process... and these are at a great price right now...
http://www.summitracing.com/parts/sum-340111/overview/
Any pictures from those are you that have installed them?
I'm curious about placement with my existing hot-side tubing on the driver's side.
Old Jun 1, 2014 | 10:45 AM
sfiore's Avatar
Default Brackets
I used the front brackets from holley
Purchased thru jegs performance
Pictures on in my build thread
1952 fleetline update
They worked out better than expected
Gave a factory look to setup
Old Jun 1, 2014 | 02:04 PM
ryanleiker's Avatar
Ya, I dig the holly stuff, but it's not cheap. And I'm kind of way past factory looking stuff.
Old Jul 15, 2014 | 08:47 AM
ryanleiker's Avatar
My idea is to possibly retrofit this bracket into the truck accessories to use a type II pump. I was hoping to be able to find some pictures of how this bracket fit on the ls1 motor... no luck so far.
