Motor whistles
Old Jun 15, 2014 | 12:03 PM
Tramminc's Avatar
Default Motor whistles
I thought it was because maybe the air filter was under sized, I removed it. then i slightly increased the motor speed, and still got a whistle sound. it's possibly a fitting or gasket leak.
Old Jun 15, 2014 | 12:05 PM
1989GTA's Avatar
Sounds like an air leak. Than again are any young women walking by when this happens?
Old Jun 15, 2014 | 10:45 PM
spacemanspif's Avatar
Mine whistled until I realized that the fresh air supply for the PCV valve that is on the passenger side valve cover needs to have a tube routed to some filtered air after the MAF. On the truck engines there is a small molded hose the runs right from the VC to the intake on a spot that isn't under vacuum right behind the TB.
Old Jun 16, 2014 | 11:45 AM
oldgoat69's Avatar
Some sort of small vacuum leak. Check all hoses for cracks. You can fog areas with start fluid, any changes in rpm will confine the search area.
