Water temp sensor / IAT
Old May 19, 2004 | 05:55 AM
Scooter70's Avatar
Default Water temp sensor / IAT
I'm connecting my harness and there's a connector near the alternator that I have labled as Coolant Temp Sensor but I don't see any sensors on the block anywhere near there. Where is it supposed to go? (Maybe the sensor is missing and I just didn't know.)
Has anyone had luck putting a resistor in the connector instead of the IAT in the intake pipe? I thought I remembered reading about John B. doing it and having some issues. Should I just go buy the sensor?
Thanks in advance,
Matt
Old May 19, 2004 | 07:57 AM
John B's Avatar
Moderator
The temp sensor is on the drivers cylinder head just above and to the left of the number 1 spark plug. Should be a brass sensor.
Old May 19, 2004 | 10:19 PM
Budman78's Avatar
Launchin It!
There a few IAT relocation kits on ebay. Check those out. I think you just mount the sensor in the grill instead of the intake plumbing.
Johns right about the sensor location.
Old May 20, 2004 | 10:30 PM
John B's Avatar
Moderator
For the tuning hassles it cuased me I would recommend either buying the sensor or using the newer MAF with it built in and buy the adpater harness...that's what I use now.
