Radiator help with lq swap
Old Jun 19, 2014 | 10:38 PM
transamfreak01's Avatar
Default Radiator help with lq swap
I have a 2001 trans am. Swapped a lq motor in it and I'm debating on buying a new radiator. I'm looking to stay at a low cost budget one. I have heard zap or a lt1 radiator is a better choice than a ls1 but I do have a ls1 radiator now. The car is an a4 with a trans cooler. Could use some help guys thanks
Old Jun 19, 2014 | 11:16 PM
gofastwclass's Avatar
Why switch radiators is the LT1 radiator supposed to be larger? I would take some measurements before laying out the cash. Are you having a cooling problem? Staying "low cost and budget" in my book means using what you already have if it's not damaged.
Old Jun 19, 2014 | 11:49 PM
The lt1 I believe doesn't have the transmission cooling in it. The actual unit is the same size but core is bigger. This is what a few turbo buddies of mine have done. Not having a cooling issue just figured it could always help. Just don't want to spend 500-1000 on a radiator and figured the zap for 130 or the lt1 would be a cheap upgrade to mine
Old Jun 20, 2014 | 12:13 AM
sprayed99's Avatar
The trans cooler is in the tank not part of the core. Just pull the lines and re make them to a separate cooler up front for the transmission. Doing that will also help that problem prone 60E last longer. If the car isn't running hot now you aren't going to increase the overall efficiency by using either of those 2 options.
Old Jun 20, 2014 | 12:17 AM
I'm running a trans cooler now. But ok then I guess I'll just keep mine. Thanks
