conversion help
Old Jun 29, 2014 | 01:03 PM
anfking6908's Avatar
Default conversion help
I have a 77 Camaro 250I6 factory a/c. My dad and I are looking to swap in a LS based engine. A few questions, As far as the A/C and Pwr Steering would I use the ones from new engine or make brackets for the old ones. If I use the new A/C do I need to change out Evap, condenser ect or will the old be compatible. The A/C on the car was re-done recently.
Old Jun 29, 2014 | 02:14 PM
vazfx16's Avatar
I think you would use the AC Comp and Pwr Steeting from the new engine. I don't know about the evap...but I would suspect that you would use the old evap.
Old Jun 29, 2014 | 10:07 PM
1964SS's Avatar
Since your AC is new I would look into one of the Holley mounts so you can re-use your system. Then use the LS power steering pump and adapt to fit your steering gearbox.
Old Jun 30, 2014 | 12:28 AM
DW SD's Avatar
as long as the compressor is fixed displacement, it should be compatible. nothing magical about using hodge podge of AC parts.
I would use the new pump and compressor and did in my conversion. You will likely need adapter fittings on the pump and AC compressor. And to change the hose lengths.
I would try running the stock accessories. They worked for me with some small adjustments. I had to space out the compressor pulley and build a new compressor belt tensioner in my L92 swap.
Old Jun 30, 2014 | 07:34 AM
Oscar Will's Avatar
I used all the 1998 F body accessories including the ac compressor. My car has been on the road for 11 years, still works fine.
