Alternator only ???
Old Jul 15, 2014 | 11:37 AM
BobH's Avatar
Default Alternator only ???
Does anyone run just an alternator only?? I haven't seen and bracket arrangements to accommodate this set-up.. If so can u post a link for this set up. I have an LS2/T56 (06 GTO) with balancer same dimensions as Fbody. Also factory mechanical water pump
Thanks
BobH
Old Jul 15, 2014 | 04:08 PM
99MUSTANG5.3L's Avatar
Yes I run just the alternator. Search low mount alternator on here and it should come up for you.
Old Jul 15, 2014 | 09:28 PM
i r teh noobz's Avatar
I'm running the F-body alternator bracket only. No idler pulley.
Old Jul 16, 2014 | 12:51 AM
BobH's Avatar
Thanks for the responses. What do u use an adjustment on the body set up ? I have a 06 gto set up.
Thks
BobH
