LS wiring conversion in Houston
Old Jul 26, 2014 | 06:31 PM
Cuate's Avatar
Default LS wiring conversion in Houston
Any recommendations of people around the Houston area that do LS swap wiring and computer flash. I'm removing a 5.3 motor and transmission and complete wiring from a 2001 Tahoe and planning to install in a 1968 chevy truck.
Old Jul 26, 2014 | 09:22 PM
Mike_hawk's Avatar
You should use lt1swap.com and do the harness yourself, the guy that runs it flashes PCM's for $75. To make your own harness you only eliminate the stuff you don't need, and add 12v constant/ignition, and ground and a few relays. Plus you can route it how you want to and make it look cleaner. I made my own, got my PCM flashed and then I could drive it to a tuner because I'm cheap.
Old Jul 27, 2014 | 05:11 AM
LS1 pwrd NOVA's Avatar
I'm going to try and do my own harness also.
Can't hurt to try to yourself as many peeps have done it.
Take about a day or two if you do it yourself but you will save $$$
Old Jul 27, 2014 | 01:16 PM
Cuate's Avatar
I'm all about saving money. Thanks for y'alls information, I'm looking at the wiring diagrams but not sure if I will be able to complete it my self.
Old Jul 28, 2014 | 06:34 PM
Take your time, label and your good.
Old Jul 28, 2014 | 06:50 PM
Nilla's Avatar
The lt1swap guy has a facebook page, under the albums he has pic by picture tutorials
https://www.facebook.com/pages/LT1-S...=photos_albums
