coolant bypass line ?
Old Aug 6, 2014 | 10:01 PM
Poncho72's Avatar
Default coolant bypass line ?
so i finally got the engine for my build a few days ago (06 LQ9 6.0), and i noticed while stripping the engine down that the coolant bypass is only on the front. the rears are blocked off on each side. should i add the rears to the mix or leave as is?
Old Aug 6, 2014 | 10:33 PM
V8Rumble's Avatar
IIRC, the later engines switched to using only the front steam lines. I'd confirm that just to be sure, but I don't think that I'd be too worried about that. (Of course if you wanted to run the rear lines as well, I doubt that it would hurt anything...)
Old Aug 7, 2014 | 06:21 AM
1slo5ohh's Avatar
Yea I'm just getting into the ls stuff but I'm pretty sure rumble is right, newer engines only used the fronts. I'm going to just run the fronts on my build.
Old Aug 7, 2014 | 10:34 AM
bczee's Avatar
No issue with it having the rear blocked off. No sure of the years that they switch to just having it blocked off, but they did come that way.
The LS1 engines (and others) that when switching intakes (ie, to a LS6) has to modify the intake or switch over to the rear blocked system due to the clearances between the valley cover and the intake. GM found that the connected system were not really needed, and most likely cheaper and saved a few cents.
Old Aug 7, 2014 | 06:59 PM
Poncho72's Avatar
thanks, my 06 LQ9 came blocked off from the factory. guess i'll leave it that way.
