fuel trim issue..need help pls
Old Aug 12, 2014 | 09:33 AM
Joe Lluvia Avila's Avatar
Default fuel trim issue..need help pls
I recently got retuned on my 5.3 cammed ls swap fox body. My tuner saying my fuel pump was giving out once i hit 5500rpm he added extra fuel to avoid engine leaning out. So the issue was fixed and it was only the fuel filter that was clogged. Now i can not get ahold of my tuner anymore. now i'm stuck running rich throught all rpm. Even leaving on idle it hesitates because of the extra fuel. should i reduce the PSI on the FPR to compensate for that extra fuel for the mean time?
Old Aug 12, 2014 | 07:28 PM
fire67bird's Avatar
I suggest that you should buy HP tuners and a wide band so you can tune it any time you need too. Lowering the FPR a few PSI probably won't hurt but going too much and leaning things out a lot will so be careful.
