06 5.3 build
Old Aug 23, 2014 | 06:57 PM
JLane9992's Avatar
Default 06 5.3 build
I'm building a 5.3 to put into a x frame 62 or 63 belair and i know for fitting purposes I need a f body oil pan and I have to relocate the alt and p/s . Instead of buying a aftermarket set up couldn't I use the accessory brackets off of a ls1 ??? If anyone could shed any light on this that would be greatly appreciated .
Old Aug 23, 2014 | 08:04 PM
ls1nova71's Avatar
You could, but then the truck stuff will also fit, at least it did on my buddy's 59. Even the truck intake clears the hood.
Old Aug 23, 2014 | 11:22 PM
JLane9992's Avatar
I'm trying to keep from having to cut anything , but if I decided to go with a ls1 intake wouldnt I have to move my accessories ? Also I'm doing a cam swap what would be a good set of lifters, values, and springs to go with and the most affordable place ro get them.
Old Aug 23, 2014 | 11:30 PM
superdave84's Avatar
Waterpump neck will be in the way of the throttlebody if you switch to a car intake. On the older cable-operated TB's, you can just take a ball peen hammer to the waterneck and dent it slightly where the TB touches. I thiiiiiiink the truck motors after 2002 do not have cable TB's, so I don't knwo what kind of clearance issue there would be on your motor.
Old Aug 24, 2014 | 01:44 AM
JLane9992's Avatar
I believe its factor drive by wire but when I got the motor it didn't have the tb or maf that was the main reason I wanted to switch over to the ls1 intake . I can get one out of my local yard for $80
Old Aug 24, 2014 | 01:47 AM
JLane9992's Avatar
Or do you think it would just be easier with the truck intake
Old Aug 24, 2014 | 03:50 PM
JLane9992's Avatar
I'm also wanting to hack my own harness . Is there a particular year i should look to get it out of ?
