4L80E transmission yoke
Old Aug 28, 2014 | 01:13 PM
Houston_t's Avatar
Default 4L80E transmission yoke
Can someone give me a part # for the yoke in need to buy for a 4L80E. Going in a second gen camaro.
Old Aug 28, 2014 | 02:56 PM
jmd's Avatar
jmd
32 spline big GM for TH400 application.
Old Aug 28, 2014 | 04:36 PM
ls1nova71's Avatar
I dont have a part number, but just an FYI, although the spline is the same as a 400 turbo, the 4l80e's outside diameter is larger by quite a bit and It's longer. I tried the 400turbo yoke and it didnt even touch the seal.
Old Aug 28, 2014 | 08:07 PM
chevcraz's Avatar
Another point of caution is the output shaft type. If it has a threaded hole it is a short spline and will require a special yoke. Solved my swap with a Denny's drive shaft and special yoke.
http://www.dennysdriveshaft.com/p69_...truck_tra.html
Old Aug 28, 2014 | 10:03 PM
Houston_t's Avatar
So where did you get your yoke from and what did you ask for or tell them?
Old Aug 28, 2014 | 10:19 PM
ls1nova71's Avatar
I got mine at the Pick-n-Pull, just found a truck with a 4l80e in it and sawzall'd the end of the driveshaft off.
Old Aug 29, 2014 | 12:07 PM
ryanleiker's Avatar
I used the Strange part number: U1650
But as was said, there are two different types of shafts. I believe this Strange yoke will work for the majority of them out there though.
