spark,fuel,no start
Old Sep 4, 2014 | 04:41 PM
lsxRanger94's Avatar
One keyed power wire? or Multiple keyed to multiple locations?
Old Sep 4, 2014 | 05:03 PM
ls1nova71's Avatar
Originally Posted by kilrcady
I get 12v on the pink wire with the key on.When I crank it I lose the 12volts.What am I missing?
Exactly what pink wire are you referring to? Also, if youre losing power to the main ignition relay in the LS harness, you wouldn't be getting spark, so how do you know that you have spark? You need to hook the LS harness's ignition relay to the wire that originally went to the coil, but it will be a resistor wire so you should replace it with a regular wire at the bulkhead connector on the firewall. That is the wire that is hot in run and crank. If you have the ignition relay hooked up in the fuse box itself, you most likely have it on a secondary ignition that is only hot in run, such as the heater blower motor and radio circuits that loose power while cranking. To test it, you could turn the key to on, then bump the starter solenoid with a screwdriver and it should start.
Old Sep 4, 2014 | 05:29 PM
ijimmy's Avatar
ITS THE VATS , injectors run off of pulse ,, to the negitive side , if you have power to the injectors it does not indicate the vats is off , almost every time the engine will run on start fluid , and not without its the vats , assuming you have fuel pressure . vats interrupts the ground on the injectors , not the positive , the positive is constant,, you can buy me a beer latter
Old Sep 4, 2014 | 05:35 PM
kilrcady's Avatar
ok.I spayed starter fluid into the TB and it ran for a few seconds.Thats how I know I got spark.The pink wire I refer to is the pink wire on the injector.I do believe like you say I had the switched power to a wire that shut off on starting(Like radio,blower)So I ran a hot wire right from the battery and the noid light flashed twice.I then pulled the fuel rail and hit the key again.No fuel from the injectors.I pulled the injectors and fuel pored from the rail.I'm going to soak them overnight in seafoam like one of you suggested.I have to find a power on when key on in my harness.What do you suggest?Also I checked all my grounds.I was very careful to scrape off paint and clean all the connections when I put them on.I also grounded the body to motor,frame to motor and body to frame.I tried the noid light one more time and it did 2 flashes then a break then 1 flash.almost like a miss.But no fuel passed the injectors.Would this be a vats issue?Thanks again guys you are keeping me sane........for now
Old Sep 4, 2014 | 07:16 PM
ls1nova71's Avatar
If it is VATs, then it WILL run for a second or two, that is if your injectors are not stuck. Clean them and then try it. Your noid light test could be a VATs thing, but I wouldn't concentrate on that until you know for sure the injectors are spraying.
As for the power wire, hook it to the wire that originally went to be coil, just make sure its a regular wire and not a resistor wire because if it is, you wont be getting a full 12v to the ignition relay.
Old Sep 4, 2014 | 07:59 PM
kilrcady's Avatar
Thanks Jimmy I will buy you a beer later AFTER I prove you right when I disable the vats.Right now I'm soaking the injectors in seafoam.
Old Sep 6, 2014 | 08:33 PM
SSZ's Avatar
SSZ
Was this the Vats or another issue?
Old Sep 11, 2014 | 06:05 PM
kilrcady's Avatar
It was the VATS! it was the VATS!Thanks ijimmy
Now it wont keep running.It starts and stalls almost immediately.Pulled the fuel rail and it squirts at the injectors.After checking with the noid light and confirmed injector pulse.I hit it with starting fluid and it runs for 2-3 seconds.I discovered a fuel leak and went to pick up a fitting.I'll try again tomorrow.anything else I should look at?
Old Sep 20, 2014 | 12:41 PM
kilrcady's Avatar
bought one of those sleabay vat delete and I now get a fire then off.Also power to the OBD port and my lights even when the key is off.Had a fuel tank leak and had to drain the tank and have it fixed.I just got back to this this morning
Old Sep 20, 2014 | 06:04 PM
OBD2 port is hot all the time and typically the same circuit as cigarette lighter. I would check power circuits to engine harness to make sure your Keyed hot is hot during crank and run and 12+ is hot all the time. Also check your fuel pressure(58psig).
Old Sep 20, 2014 | 09:16 PM
kilrcady's Avatar
58 psig...will do
Old Sep 21, 2014 | 01:19 PM
  #32
kilrcady's Avatar
got a fuel pressure gauge and wasnt getting any reading.So I disconnected the line to the fuel rail and it kinda dribbled out.Disconnected the fuel filter at the tank and blew air through.All clear.Cleaned the filter.It was all clean.Drained the tank(Again)and dropped it.Pulled the pump and did a bench test in a bucket of water.Came out like a low faucet on your sink.It really should blast.Wasnt to pleased.Got much better from my Holley red pump on my carbed big block.I think the pump is just tired.It worked when pulled from the running TA I got the motor and trans from.Just ordered a new pump.Cant hurt.
Old Sep 21, 2014 | 05:28 PM
  #33
66duce's Avatar
Hot on run and start on my 68 camaro was the pink wire on ign. switch. Thanks belongs to bezee
Old Sep 21, 2014 | 05:48 PM
  #34
Jimbo1367's Avatar
Kilrcady,
Hurry up and fix this. I have the same problem.
Old Sep 22, 2014 | 07:52 PM
  #35
kilrcady's Avatar
waiting for the pump
Old Sep 25, 2014 | 08:17 PM
  #36
kilrcady's Avatar
YEAH!!! It was the fuel pump.Replaced it a got 49 lbs just on static pressure.and it fired right up.Found another small fuel leak but I think it was me rushing
Old Sep 25, 2014 | 11:21 PM
  #37
bczee's Avatar
Great to hear it is now running ! Glad and the others have helped out.
Keep the updatrs coming.
Old Sep 26, 2014 | 03:59 AM
  #38
kilrcady's Avatar
you guys rock
