ls1 240sx
Old Sep 4, 2014 | 09:09 PM
ben husen's Avatar
Default ls1 240sx
finished my swap a few days ago it started on the 3rd crank next day it starts starting hard gotta try starting it 3 times 1st time nothin 2nd time get a good backfire out the exhuast 3rd time starts perfectly fine getting code p0343 wich is high circut cam sensor iv searched but havent really found anything i ohmed out the plug the signal wire is 54 ohms the negative is 74 ohms and the 12v is 0 ohms.
i just soldered on the new cam sensor connector before i put the motor in so i wouldnt think it would be that could to few of grounds on the motor cause the high ohm reading? i only have a few but none of them are to the head
the motor idles fine but almost feels like it has a miss when getting on it but then some times wile getting on it it has full power.
buddy hooked his scanner up my fuel tables were kinda all over but reasonable mods are intake 5 pin maf and headers ecu was sent out to get reprogramed for the 5 pin maf could them mods mess with it to?
sorry for the runon sentence and poor punctuation
