Removing Smog on a E-rod Crate Engine
Old Sep 16, 2014 | 06:21 AM
TransAm_Stan's Avatar
Default Removing Smog on a E-rod Crate Engine
Hey peeps!
As the title says I want to remove the smog equipment on a new LS3 E-rod crate engine.
I have looked around & do not see anything on the web about such a process. Any hints on where to look?
Yeah I know I could have bought a different motor but I found this at a pretty good price.
Oh, and I am pretty LSx illiterate, but learning fast!
My guess is that I would ditch the cats, computer, wiring, charcoal canister & procure a different computer & harness.
I assume I could sell the take-off's to offset costs, eh?
I would love to hear your thoughts!
Regards,
Stan
Old Sep 16, 2014 | 08:17 AM
Jones'n's Avatar
Umm... take off the things you don't want... have the computer reprogrammed to turn off the emissions... done.
Old Sep 16, 2014 | 08:38 AM
garys 68's Avatar
You just need to chop off the cats, eliminate the purge solenoid/evap, reprogram what you have, and you're done.
But I don't see much advantage in that. You'll have another $100 in the ecu tune. And for resale, often having an emissions compliant motor is a big plus.
Old Sep 16, 2014 | 09:56 AM
Thanks for the replies gents.
Seems like a pretty easy thing to do other than the programming. At this time I have not found a person to program my stuff. I know it is WAY beyond my capabilities.
Who would you suggest to retune my ECU? I not at that point in my swap yet, but getting there.
Could the items I take off/eliminate be put on another LSx(3) and make it smog compliant? If so I think I could unload what I have & help somebody out.
Gary what you say is correct. WV does not have a smog check. And by the time this car is sold, I will be 6 feet under...
Again, mucho thanks for answering these newbie questions!
Old Sep 16, 2014 | 12:05 PM
Project GatTagO's Avatar
Get rid of the cats and keep the other stuff. It doesn't cost any HP and eval hardware will greatly reduce the general stink of the car. win-win.
Andrew
Old Sep 16, 2014 | 12:19 PM
1970camaroRS's Avatar
How much is the erod ECU able to be tuned?
Old Sep 16, 2014 | 04:41 PM
bczee's Avatar
Question... why did you use a eRod setup only to remove the parts that make it a smog compliant swap. ?
You could have save $2k with using a standard create engine and setup.
I have not heard of any one tuning an eRod ECM yet... that would possibly void the CARB Certification. But I take it your not worried about that.
But back to the question..it just comes down to removing all of the Smog equipment and disable the DTC codes and functions as needed. May as well have it Dyno tuned while your at it.
Old Sep 16, 2014 | 04:49 PM
lsxRanger94's Avatar
The exhaust manifolds you have are the same as 2010 Camaro, so the cats will bolt to the 2010 Camaro flange. Fitting the chassis is another question.
Old Sep 16, 2014 | 06:30 PM
reedld's Avatar
How much HP can really be gained from removing items (which may be difficult to sell) AND then paying for a tune? I'd run it as is...keep the warranty. 430 HP WITH emissions....nice setup.
Old Sep 16, 2014 | 06:39 PM
bczee's Avatar
C.A.R.B certification is very specific. You have to install and use all reqired parts. Moving the removed parts to another car/swap will not make it legal to pass as a C.A.R.B swap.
Old Sep 16, 2014 | 09:03 PM
Who is to know if the parts were moved if all of them were moved together?
Andrew
Old Sep 16, 2014 | 09:22 PM
1FastBrick's Avatar
FYI the E-Rod Crate engines use a factory style ECU. IIRC it's an E67 Style. They just have different Programing in them and NO transmission control.
They can be re-programed just like any other controler.
The E-Rod harness is wired for an aftermarket Trans Controller and harness.
