ls6 heads and cam i need help
Old Sep 24, 2014 | 08:41 AM
b body professor's Avatar
Default ls6 heads and cam i need help
hello ,
am planing to ls swap my b body 96 impala ss , i got ls1 engine with trany
from junk yard and will be rebuilding both,
problem is am not that expert in ls engines , but i bought a book
so this project will be daily driver , and since i have no expert in cams
i need any help i can get , and i will really appreciate any inputs and help
i want a stock idle cam and dead silent jest like stock but with more power
so ls6 stock cam with heads and manifold is a good choice ؟؟
also should i use a stock ported and shimmed oil pump ? or a stock one will do jest fine ?
and i'm confused which size of headers should i go with this set ?
thanks in advance
Old Sep 24, 2014 | 11:53 AM
Old Sep 24, 2014 | 03:57 PM
lsxRanger94's Avatar
So you want more power in a 3800-4200lb car with smooth idle. Look at aftermarket "truck" grinds to help boost torque.
Old Sep 25, 2014 | 06:54 AM
thank you
