VSS w/ NVU Guages
Setup is a GMPP LS3 T56 w/ GMPP computer. I am taking the VSS off the computer right now, not the sensor itself.
Issue right now is that I get signal but it's just under 2k/mile. NVU says it should be around 4k/mile. I don't have a scan tool or o-scope to see what the computer is doing. I also replaced the VSS and it's the exact same result.
I had the NVU calibrated for this and thought I was done but some how it lost the setting and went back to 4k setting. Emailed NVU asked them why it lost the setting and it turns out they don't want any setting under 4k. They also have a low, mid, high setting for signal, any idea what GM wants? I didn't play around with that yet, NVU setting out of the box is mid.
Questions:
- anyone ever encounter this with the GMPP computer on factory tune?
- if I tap into the VSS directly which wire is the 'high' side or doesn't it matter?
TIA
Just looking to see what the experience has been with a stock GMPP computer.
Thx.
