GenIII 5.3l in 06 CTS
Old Oct 12, 2014 | 06:41 AM
John.'s Avatar
Default GenIII 5.3l in 06 CTS
So I bought a 06 CAD CTS with a spun bearing with plans of swapping in a 5.3l truck engine and 4l60. Any thoughts on what oil pan will be needed? I don't think a truck pan will work for me. I'm new to the ls engine so may have alot of question so help will be greatly appreciated. I will add pics during transplant. I haven't bought the truck yet so if 5.3l wont work maybe there is reasonable alternative. Keep in mind if I could afford the v model I would already have it.
Thanks
John
Old Oct 12, 2014 | 08:26 AM
Project GatTagO's Avatar
Thanks
John
John,
If the front cross members are the same between the v and non v models, then you can just use the CTS-V pan...
Andrew
Old Oct 12, 2014 | 08:31 AM
You might be fucked...Looking at the CTS and the CTS-V pictures, it looks like the crossmember might have been different:
https://archives.media.gm.com/us/pow...g%20trans.html
My guess is that the engine cradle is removable and the easiest thing to do might be to get a V cradle, then you can use the CTS-V pan.
Andrew
Old Oct 12, 2014 | 01:38 PM
99MUSTANG5.3L's Avatar
I want to do a similar swap, an 08 CTS or newer. I have an 08 CTS4 and it's a great car for the family, but I want more power. I have been considering a theft recovery or slight accident.
Old Oct 12, 2014 | 08:26 PM
S10xGN's Avatar
On any of these "late model" swaps, there'll be a whole lot of "gotchas" before you're up and running. Even going from a CTS to a "V", there's gonna be a ton of differences in everything from basic hardware to wiring to computer(s)...
Old Oct 14, 2014 | 08:40 AM
71ANTICARB's Avatar
You will prolly be money, time, and frustration ahead to just buy a real "V".
Old Oct 15, 2014 | 05:18 PM
Every swap has it's snaggs and frustrations. If you can make a stand alone harness for your motor and trans how hard can it be or am I missing something with the other systems in these newer cars? I.E. the BCM. I have heard about Caddy using the CANBUS and people having issues with integrating a stand alone harness with the CANBUS system. Anybody have any input or experience with the canbus systems?
