LS2 wiring questions???
Also the would like to delete low reference wire from pin 49 ( was wired to the AC system sharing a plug with pin 51) from C3 and EVAP canister vent sol control from C2.
Lastly the Reverse Lock Out solenoid?? It was originally thru the BCM but I am not running the BCM. What is the best way to wire the Rev Lock Sol??
Thanks,
BobH
Thanks
BobH
Anyway I guess i will fix that wire at pin 44 on C2 that was marked Low coolant level. I found another schematic that I traced in return and it shows that wire going back to the Cam Sensor as 12v....???
I still cant find the schematic that shows the EVAP canister sol. That wire feeds from PCM connector to plug at right bank connector at center of vavle cover (the connector also has wiring for inj and coils)
Inch by Inch,
BobH
FYI, I found all of this information in seconds with a simple Google Image search.
Tipsy
Tipsy
I just hooked up the suspect wires back in the harness.
Later,
BobH
I actually thought I had this worked out until I back t
For the record, you can use Google to search this (or any) site very efficiently.
Examples:
ls2 gto pinouts site:ls1tech.com
"skip shift" delete site:ls1tech.com
I made that mistake when I did my swap and discovered some of them are actually for the same year Corvettes. The wiring (colors\pinouts) ARE different between the two cars.
Just sayin'
