A little smoke
Old Oct 28, 2014 | 10:48 PM
Grewe02's Avatar
Default A little smoke
Finally had some pipes put on after 6 years of just headers. I'm mostly sure I had a tune put on it while it was just headers. Could this just be an issue of getting a new tune? Or do I need to start replacing gaskets?
Old Oct 28, 2014 | 11:27 PM
1970camaroRS's Avatar
That's not a gasket issue. Is that a cold-start? Does it get better when it warms up? Looks like a hint of blue to it, so maybe you're getting oil leaking past the valve seals.
Old Oct 29, 2014 | 05:30 PM
lsxRanger94's Avatar
Blue smoke when you rev it is usually rings or piston. At start up is usually valve seals. Blue and black smoke is usually a rich running engine washing the cylinder walls down. I'd do a compression check to be safe and have a look at your tune.
