Long tube header
Old Nov 5, 2014 | 11:58 AM
laurentj23's Avatar
Default Long tube header
Ok guys. I'm swapping my ls into a Nissan 240sx. They cam with different type of mount kits. I bought one frm fueled performance but I'm using joker header.
If the header won't like the steering shaft is on the way or it touches the frame rail, what do you guys usually do besides getting another header?
I'm dropping the engine sometime beginning of dec and I want to get everything ready.
Old Nov 5, 2014 | 01:12 PM
user 4737373's Avatar
Your best bet is to use mounts and headers from a single supplier to ensure compatibility. The fitment of the headers around the steering shaft in your car is very exact and even slight fore/aft or elevation changes to your engine from using different branded mounts will cause a well designed header to fit poorly.
Old Nov 5, 2014 | 02:37 PM
2muchboostNY's Avatar
^^^Yup. Any pix to share? Sometimes I have seen people heat up and manipulate header plumbing to make it work. I will look for an example.
