manifold port
Old Nov 18, 2014 | 10:40 AM
lilrobo's Avatar
Default manifold port
is this what i need for my manifold , its not a egr that's top of intake right ?
this is on top of the manifold the holes are 1 3/4 apart i believe , i bought one from another place and the holes were too close 1 1/2
thanks
http://www.ebay.com/itm/LS1-AIR-SYSTEM-BLOCK-OFF-PLATES-98-02-CAMARO-FIREBIRD-/321588256472?_trksid=p2054897.l4275
Old Nov 18, 2014 | 05:07 PM
ls1nova71's Avatar
thanks
LS1 Air System Block Off Plates 98 02 Camaro Firebird | eBay
Need a litle more info. If you have an older LS1, then they have an EGR tube that goes in the top of the intake right behind the throttle body,, but its a round hole. Some people use a freeze plug to plug it. The EGR goes into the right manifold only, and the bolt holes are roughly 1 1/2" apart. What you have pictured is for blocking off whete the AIR tubes originally went in the exhaust manifolds, those bolt holes are roughly 1 3/8" apart.
Old Nov 18, 2014 | 05:45 PM
lilrobo's Avatar
i did a rubber plug in the one on the intake,, i ordered one from speedway motors this one but the holes didn't line up i was told that 02 didn't have egr in 02 ? i don't know ,, i am using 02 camero manifolds on y 55 on the drivers side to help with clearance issues , its right one top , thanks http://www.speedwaymotors.com/LS-EGR...te,103755.html
