problems installing ls7 clutch kit on ls1
What engine? 5.7 aluminum block LS1? Out of what? Corvette, f body, GTO, etc.
You have a T56, where is it from? Was it bolted to the engine before and worked?
Did you get an LS7, flywheel and clutch?
Details on the throwout bearing.
Which pilot bearing are you using? Good pics above.
There are a lot of incompatibilities that could cause the issue, starter, pilot bearing, throwout bearing, etc.
And if the parts guy actually told you "I needed an extension for my input shaft" don't ask him anything else...ever. There is one combination where that would almost make sense, but there is no such thing as an input shaft extension.
You don't know if you have the correct pilot bearing unless you know the trans/bell. GTO, f body T56 use the small inner bearing. CTS-V uses the large outer.
GTO bell will have starter interference issues on an f body LS1.
If you have a LS7 clutch and a f-body T56, you have to use the LS1 small pilot bearing and the F-body bearing.
Andrew
