Ls7 oil pan options
Old Nov 24, 2014 | 04:39 PM
rhyspw's Avatar
Default Ls7 oil pan options
I am doing a ls7 conversion and I am having trouble packaging the exhaust on the side of the oil pan inlet and outlet due to the proximity of the chassis rails. So I can't get both in the same area and am looking at different oil pan options. I have tried the oil adaptor plates with an fittings and have also machined up a bespoke manifold but there is not enough room.
Ideally I would like a pan that the oil inlet and outlet would be at the front of the engine. It needs to be a standard swop as I will be using the standard oil pump etc. Car will be used as a road car and occasional track days so not racing.
Please can you advise on options to modify the existing pan or any off the shelf items that would meet the above criteria? Obviously cheaper the better but quality is a must....
Many thanks
Old Nov 25, 2014 | 04:07 PM
rhyspw's Avatar
Looking for a pan with front oil inlet and outlet like this but have spoken to ats ( speed tech) and they don't make them:
http://i88.photobucket.com/albums/k1.../ATSLS7Pan.jpg
Any ideas appreciated
Old Nov 25, 2014 | 04:31 PM
Project GatTagO's Avatar
Did you call them recently? I seem to recall that they were making the LS7 pan again.
Andrew
Old Nov 25, 2014 | 04:48 PM
rhyspw's Avatar
Yep called today. The only one they do it the one on their site :
http://www.speedtechperformance.com/...rod/prd273.htm
