Cruise control wiring
Need info on the cruise control actuator for a 99 GM (think the unit is from a mid-nineties vehicle), want to use unit on a 1999 LS1 engine and trans in a Jaguar XK8. No necessarily look for all the features...can live with just speed hold. I would need to know wiring for pwr, VSS input, brake switch and control engage. Any help would be appreciated,(picture of unit and wire pig-tail included).
Thanks
Thanks
Wires on plug are as follows...
A - On/Off
B - Set/Coast
C - Resume/Accel
D - Brake light switch (hot when pedal NOT depressed)
E - Ground
F - Ignition power
G - Brake light switch (hot WITH pedal depressed)
H - empty
J - Cruise engaged signal wire (Not needed)
K - VSS from PCM
Hope this helps
A - On/Off
B - Set/Coast
C - Resume/Accel
E - Ground
F - Ignition power
H - empty
K - VSS from PCM
Hope this helps
A - On/Off
B - Set/Coast
C - Resume/Accel
E - Ground
F - Ignition power
H - empty
K - VSS from PCM
Hope this helps
A - On/Off
B - Set/Coast
C - Resume/Accel
E - Ground
F - Ignition power
H - empty
K - VSS from PCM
Hope this helps
