Ls1 map sensor relocations - pic request
Old Dec 19, 2014 | 07:39 PM
etijsma's Avatar
Default Ls1 map sensor relocations - pic request
On my ls1 intake I had to remove the part that holds the map sensor since the firewall and cowl were in the way.
Does anyone have any pics on a slick way of adding it somewhere else that didn't look sloppy? I googled images but didn't come up with much.
Old Dec 20, 2014 | 08:11 AM
33willys's Avatar
Default MAP sensor
Megasquirt did a test on relocating their MAP sensor. They found out that a vacuum hose of ANY lenght had no effect on the sensor reading. Their MAP sensor is different than the GM sensor but vacuum is vacuum. If you can find a place to attach a hose and run it to the sensor somewhere out of sight the only restriction would be the wires. On an LT1 engine I unplugged the MAP from the manifold mounting, attached a hose to it, dropped it into the valley and covered it with the LT1 valley covers. Worked for 13 years.
Old Dec 20, 2014 | 08:25 AM
lsxRanger94's Avatar
Many of the turbo guys are doing this with the 3 bar map and you can mount that one on the firewall if needed.
