Fox Body steering column adjustment
Old Dec 21, 2014 | 11:51 PM
NV Z 28's Avatar
Default Fox Body steering column adjustment
I am in the process of 4.8 swapping my 89 fox body. I am running a AJE k member and Kooks 1 7/8 headers and the header is hitting the steering shaft very slightly. I know the steering shaft can move in and out (which isnt really helping me) but is there a way to move it side to side? If I can move the column towards the passenger side about 1/2 inch everything would be perfect. BTW Im running the AJE steering shaft.
Old Dec 22, 2014 | 02:53 AM
booboo37's Avatar
The shaft is hitting or the knuckle ??? I had to take the steering column out once and cut the end off about a inch or 2 so the knuckle could go higher up...you might need to put a little dent in the header also..
Old Dec 22, 2014 | 08:21 AM
SSSTANG#1's Avatar
Yes, the steering shaft can be shifted around quite a bit from under the dash/behind the gauge panel. There are the two steering column mounts (four bolts), easily accessible under the dash. Also there is a bracket behind the gauge panel that the column passes through that has, I believe, four bolts that can be loosened to move the column. It is a PITA to get to.
Old Dec 22, 2014 | 09:38 AM
NV Z 28's Avatar
Yeah, the top knuckle just barely hits the header. I've tried moving it forward and back and it really does no good.
Old Dec 22, 2014 | 09:41 AM
NV Z 28's Avatar
Awesome. Thanks for the info.
So all 8 bolts would need to be loosened to get any adjustment? All I need is about 1/2" to the passenger side just to be safe. I might even be able to get away with 1/4".
Also, will this move my steering wheel off center?
Old Jan 4, 2015 | 09:20 PM
SSSTANG#1's Avatar
Correction, there are two bolts behind the instrument cluster. With everything loosened up you should be able to get 1/4".
Old Jan 4, 2015 | 10:04 PM
NV Z 28's Avatar
Awesome. Thanks!
