PCM location concern
Old Dec 24, 2014 | 08:30 AM
boostnut's Avatar
Default PCM location concern
I'm running a 411 PCM in my swap and have it jammed under the passenger side seat of a mustang. It's sitting on carpet but will come in contact with the metal seat frame while driving down the road. Everything I've read says the case doesn't need to be grounded, gm mounts them in plastic cases so that's pretty obvious. But what about intermittent contact with a ground (seat frame)? Am I looking for trouble? Should I ground the case with a wire so that the ground is constant or just run with it as-is?
Old Dec 24, 2014 | 08:50 AM
ls1nova71's Avatar
It'll be fine as long as its not moving around, and then you would most likely run into a wiring harness problem. Grounding it wont change a thing unless your harness grounds are not good.
