No connection to PCM
Old Dec 24, 2014 | 07:02 PM
gpr's Avatar
gpr
Default No connection to PCM
Finally got all the wiring on a 5.3l swap to where i could start the engine. Tried starting it but had no spark, figured it was the VATS disabling something. So i tried connecting efiLive to download the tune, modify it and reflash pcm. However, I can not connect with efilive to the PCM.
I doubled checked the obd-II port and it seems wired correct. I have continuity between pin 2 on the obd-II port and pin 58 of the blue pcm connector. The ground is good on pin 4&5, as well as power to pin 16.
What else is there to check? I tried connecting efilive using the ls1b pcm type, as i would assume that is what is used on a 2003 5.3l flex fuel engine?
Old Dec 24, 2014 | 07:49 PM
S10xGN's Avatar
Sure you have all your power and grounds hooked up?
Old Dec 24, 2014 | 07:53 PM
lsxRanger94's Avatar
Make sure pin 16 is hot at all times(typically cigarette lighter circuit) and Key is in the run position.
Old Dec 24, 2014 | 10:18 PM
gpr's Avatar
gpr
Pin 16 is powered all the time, and when i plug efilive box into it, it powers the box up. All power and grounds seem to be correct. I can turn key on and fuel pump primes, throttle body turns on and opens, the engine mil light turns on....
I have a 2002 pickup with a 5.3 lm7 and a 2002 camaro. If I swapped their pcms into this harness would it hurt anything? They are both drive by cable, and I know they changed the truck harness in 2003. I'm just wondering if my pcm is fried or "bricked", but don't know a way to test and verified.
Old Dec 25, 2014 | 09:01 AM
If it's a red/green connector on the harness then yes. Red/blue harness connector won't plug into red/green pcm without a little modification and the pinouts are different. But it can be done easily.
Check the link out about halfway down the page.
http://www.lt1swap.com/cable_conversion.htm
