need help with my 84 conversion
Old Dec 26, 2014 | 05:41 AM
wgriff420's Avatar
Default need help with my 84 conversion
Starting to convert my Monte Carlo. ISO ls2, components and transmission. Any and all help is appreciated. Thanks.
Old Dec 26, 2014 | 09:46 AM
jlcustomz's Avatar
Hooker is just finishing up a g-body swap system, which will avoid some common fitment issues by having components that work together.
https://ls1tech.com/forums/conversio...review-14.html
There is also a g-body swap thread here.
As I advise anybody, there are several different ways to do each aspect that needs to be done in a swap.
If you can afford it, personally I recommend going to aftermarket gauges & aftermarket air to clear up some under hood room .
Old Dec 27, 2014 | 12:17 AM
onebadbowtie86's Avatar
What components do you need? I'm also doing an ls2 swap to my 86 monte carlo ss.
Old Dec 28, 2014 | 05:39 AM
wgriff420's Avatar
Pretty much the entire setup. Motor, computer, harness, and trans
