oil temp sensor for LS3
Old Dec 30, 2014 | 07:44 AM
Sloe Truk's Avatar
Default oil temp sensor for LS3
Hi All, quick couple of questions. I'm putting an LS3 in my 350Z and I am also running the batwing oil pan.
1st does the LS3 PCM have a pinout for a oil temp sending unit?
2nd what would be said pinout?
3rd which sending unit is properly scaled for that PCM?
my end goal is to use a racepack IQ3 and connect it to the canbus, so the more i can read off of the PCM the fewer other sensors i need.
thank you in advance
