Tow/haul mode with indicator light?
Old Jan 3, 2015 | 11:38 AM
jeepin Jeff's Avatar
Default Tow/haul mode with indicator light?
Swapped a 2002 Yukon 5.3 and 4l60e into my jeep J10. I have a momentary switch installed to enable or disable tow/haul mode and it works fine but there is no light that tells me its engaged as there was on the original GMC dash. I don't see an output for this on the PCM either.
What I want to do is push the tow button and see a light or LED come on until I push it again disabling tow and turning off the indicator. Anybody have an easy solution to this simple problem?
Thanks
Jeff
Old Jan 3, 2015 | 11:45 AM
trozfan's Avatar
On my 4.8/6L80E swap- the original button wires to the BCM, which gives it the illuminated feedback. Not sure if it's the same on your set up.
Old Jan 3, 2015 | 12:06 PM
No BCM on my older setup. There has to be an easy way to do this. Maybe with a relay or two? In my dream, when I push the button, pin 71 is momentarily grounded and a dash light (that I install) is on. Push it again and pin 71 is grounded again disabling tow/haul and the light goes out. Anybody have a simple relay design for this?
Thanks
Old Jan 3, 2015 | 01:12 PM
G-Body's Avatar
sawzall wielding director
I had wanted to do that too. I was going to try using a circuit like this http://todbot.com/blog/2010/01/02/mo...omment-page-2/ but never bothered to get around to it.
