Starter gear sticking
When I bump the key, the engine will start to turn but then you just hear that starter spinning. The gear gets stuck in the flywheel but comes right out when I turn the engine over with a ratchet.
I've attached a pic of the starter from the top view. The gap gets wider as it goes down. The gap on the bottom side of the starter is even across.
I have no clue, I thought I remembered that you don't shim ls1 style starters. Any advice is always welcome. Thanks for looking.
Daniel
